Results 1 to 4 of 4
Thread: 1985 200x rear master cylinder help
    Jan 2004
    Los Angeles
    66
    Hey guys,
    A friend of mine picked up a 200x on saturday pretty clean, but the rear master cylinder is bad. We tried and tried to get the rear brakes working properly via bleeding and all of that other good stuff. We came to the conclusion that the master cylinder is bad. Can anyone tell me where to get a rebuild kit, or what are the options available for swapping one out from a different trike or a quad ?
    Thanks Newbie 350x
    1981 yz 60, 1983 atc 70, 1985 350x, 1985 lt250r, 1985 lt 185. 1995 lt80
    May 2002
    Dublin, Georgia
    635
    You can get the seals for the master cylinder from Honda. Thats what I did when I rebuilt mine.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Apr 2004
    International Falls Minnesota
    546
    Shadetree.com has rebuild kits for the 200X make sure you get the 83-85 model though. Thats what i did with my 200X i ordered from them.
    Minnesota
    784
    Was there any fluid or air comming out of the bleeder? Before looking for mastercyclinder rebuild kits take the bleeder out and make sure its not plugged. If air and fluid then come out and they still don't work the piston might be froze in the caliper and not squeezing the disk. Then you'd probably need new o rings in the caliper and possibly a new piston if the old one is pitted.
