Originally Posted by
hancho
Dyno tests have shown a 5% to 6% increase in horsepower. Installation is very easy. Install a set of Dial-A-Jets in the conventional manner. Now you will need a small tank mounted under your hood for the alcohol. The tank should have a fuel shut off. A remote float bowl with a needle and seat will also be needed to handle the fuel from the tank to the Dial-A-Jet. Simply hook the Dial-A-Jets to the remote float bowl and you are ready to run. This is very simple and effective, it can be used on almost any engine to safely boost performance and raise horsepower while lowering temperatures
That's a lot of work for 2hp.
