200x kickstarter questions
My 200x bottom end is all apart. I put the kickstarter stuff all in and noticed that the spring isn't touching the case when the kickstarter stop touches it. I looked at my other bottom end and it was the same. Are both springs worn out? or is it supposed to be like that? I don't want to put it all together and find out I need to replace the spring. Thanks.
85 200x - Torn apart
spring
after the kicker spring is intalled it should not touch the inside of the case except where it hooks over the lip
//ArrowChat Integreation Code
