Thread: chain problems
    Jun 2004
    texas
    70
    Question chain problems
    I have a honda 110 three wheeler. does anyone know how to get the chain of, it doesnt have a master link.
    UK
    23
    I think there are two ways, on two different models. Sounds like you have the more awkward of the two- the continuous loop. Now for the pain!
    remove recoil starter
    remove alternator assembly
    remove subtransmission
    remove lefthand crank case
    disconnect rear brake cable and completely unscrew the brake pedal adjustment nut ( at the rear of the bike that sticks out)
    unhook the brake pedal return spring and remove brake pedal
    withdraw chain tensioner from the left hand side
    withdraw the rear axle, drive chain, and drive sprocket assembly from the left hand side.
    Open heart surgery would take less time.
    This is basically the proceedure from the clymer manual but I would say unless your restoring to showroom condition, with original hardware Etc, just knock a link out the bugger and get a new chain with a master link! You will still be young enough to at least ride the bike once you've replaced the chain, that way! Hope this helps, let me know if I can help in the future Bra! Cheers
    Things that make you go...VROOOOM!
    1981 Honda 110
    1983 Honda Big Red 200e
    1985 Honda 350X
    1986 Honda Big Red 250es
    1986 Honda 250R
    1985 Yamaha YTZ250N
    Now been told "Thats enough" - NEVER!!
    Jun 2004
    geraldton, west australia
    1,068
    yea thats what i would of suggested. luckily on mine i had the breakable chain.
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Moncton Newbrunswick,Canada
    509
    my 110 was the pain in the arse one...thank god for a masterlink,i just split the chain and sat it on the top of the front sproket then used a screwdriver to turn the sprocket and feed the chain around then bring it over the rear sprocket then i realized after fighting with the chain to get it over the sprocket it was to long,so i measured it up while it was on the bike and took my angle grinder and ground a pin down broke the chain connected the link and it worked like a charm...lol
    buy a chain breaker.
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Houston,Texas
    1,044
    Quote Originally Posted by Wild250R
    Just buy a chain break, like smokinp said, or take a cutoff wheel, cut it off, and buy a chain with a master link.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Jun 2004
    texas
    70
    thanks for the help.
