Help me and my friand took off my inline filter and now there is a hose that leaks on the bottom of the carburator, it doesn't do it when the gas is off only when its on I need HELP.. and it doesn't lead anywhere is it supposed to? whats wrong?
the hose is for overflow,it dosnt connect to anything,sounds like you may need a carb rebuild kit or at least needle and seat.
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
either that or your floats stuck
Clay Whitman
Newnan, GA
AMSOIL DEALER
My Toys
2008 Yamaha Rhino 700 SE
When you took the filter off a small piece of dirt probibly went down the line and stuck on the float needle therefore stopping it from sealing.
You could try tapping the side of the carb with the end of aHANDLE with the gas turned on and see if that stops it, or the best way is to remove the carb and clean the seat and needle valve.
those older carbs are very tricky. If you are not careful when you put them back on the float sticks a bit. When you take them apart make sure it is seating ok and just be careful. Everytime I took mine off it leaked I would have to do it twice every time.
