Thread: Headlight Question for the Z
    Northern CA
    1,104
    I got my lights working today
    However they are not the original lights as you might have seen..The stock lights are 2 30w bulbs and the ones in there now are 2 55w bulbs.....For some reason these are the only ones that the Yamaha shop could find that would work in there...Honda Bulb....Anyway,,,, If I run both of them will it fry my Stator???? I'm thinking it might and just to be on the safe side just run one light....Any thoughts on this would be appreciated
    I should also say that at RPM these lights are not as bright as they should be....And at an idle....They are very dim...
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Rittman, Ohio
    6,276
    It wont damage your stator. Thats very hard to do. However your stator wont deliver enough power to light both of them them either. The Z stator delivers about 75 watts at its best. Im running two 35 watt sealed beam lights on mine, and I had to choose between running two and a lot of dimming at idle, or running one that was constantly bright. A single 55 watt unit works very well on the Z. Ive had lots of experience in improvised TriZ lighting!
    Northern CA
    1,104
    Thanks Timsr!!!! I knew I could count on you!!!!
    I have come to the Conclusion that I will only run the one lamp and keep the other as a spare and for aesthetics I only wish I would have known before I spent 15 bucks on a bulb
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    jmsmilin's Avatar
    jmsmilin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Yeah I was gonna say ask Tim Sr as Ive seen his pics, speaking of which I may go with your set up on my ATC, so what are the round lights you are running?
    RIDES:
    Current OG rides:
    ~1993 300EX 1 owner (just sold)
    ~1993 TRX90 matches the 300
    ~1996 Z50R the FIDDY
    ~1992 YSR50 (sold)
    ~ATC 70 (w/suspension), ATC 185S (w/susp), 250SX, 350X, etc, etc, ALL SOLD!
    WTB: small machines - ATC70s w/ suspension, TRX90, z50, CRF/XR70/110, CT70, CT90, SL70 etc.
    Favorite riding spots:
    1. Twin Buttes, San Angelo TX
    2. Turkey Bay, LBL KY & Linton Beach in Bumpus Mills
    3. Sunnyside ATV, Wrens GA
    Northern CA
    1,104
    Mine are PIWA....Dont know where they came from they were on the bike when I got it....
    85' Tri-Z 250
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
