Results 1 to 3 of 3
Thread: Throttle flat spot Tri-Z 250.
    Jan 2004
    Auckland New Zealand
    35
    Have got a clean 85 Tri_z 250.. It runs great at idle and starts first kick every time.. But seems to have a flat spot around mid throttle.. Im wondering if this might have something to do with the vacuum fuel pump ?? Or is it just a carb and jet problem
    Any help would be great...
    May 2002
    Southeastern Wisconsin
    3,658
    Raise you needle up one. Do that by lowering the clip one position. Your needle handles your mid range. If you need to, do it again but I suggest only one position at a time.
    Jan 2004
    35
    Thanks man I am off to try that right now
