Will the banshee foot pegs work on a tri-z?
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
hi there,
no they won't work.
the rear brake lever mount is in the wrong place.
the mounts are different too.
you can use the foot pegs themselfs.
alot of banchee parts interchange.
rear master cylinder reservoir.
the rear taillight.
the handle bars.
the rear brake hose; great for getting a extended brake hose for a extended swingarm.
the rear shock i think everybody knows that.
front and rear master cylinders:and rebuild kits.
the rear chain slide.
the headlight bulbs.
you can use the axle carrier if you use the banchee rear calipar.
i hope this helps you!!!!!!!!!!!
triztunes!!!!!!!!!!!!!
Yes it does!!!! thank you!!!!Originally Posted by TRIZTUNES
By the way! Do you have any pics of your Z's?
2006 YFZ 450
On the Banshee Rear Resi you have to cut off one of the mounts..Also,,,If you cant find one of those the 1975 RD400 is the same too....but Yamaha doesnt know that...I am pretty sure the part # is the same though...![]()
85' Tri-Z 250
85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
85' 350X
06 TRX90
78' ATC70 Project
03'250EX
87 Ninja750 3wheeler![]()
