Results 1 to 9 of 9
Thread: running at full speed for a long time?
    Oswego, IL
    1,858
    is it bad to run your trike at its max power for about 20 min or so? just wondering. like on the road if u took a lil trip on your trike and you were going full speed for a good 20 min or so. is this bad for the trike?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Apr 2003
    Central New York
    1,862
    Hmmmmmm
    I dont do it. Cant be good and I know I messed up the Head on my 4 stroke Mojave Quad from a fast to long road ride. Never was the same.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Jul 2004
    Alberta
    0
    I never do it either. I just don't want to take the chance.
    Northern CA
    1,104
    How do those Baja Guys do it then???
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Dec 2002
    Kansas
    2,387
    If I'm racing and loosing I'd do it and never think twice about it. If it blows I'll build something faster and better then before.
    If your machine has a rev limitier it shouldn't hurt it in my opinion. I think most machines are geared high enough that they don't have enough power to blow themselves up in high gear. The motor should power out before it hits the blow up stage.
    Thats just my thoughts on it. smokinwrench is not responsible for your blown engines.
    I had the RIGHT to remain silent, I didn't have the ability!
    May 2002
    Southeastern Wisconsin
    3,658
    The biggest thing is if it's tuned right. If your running to lean it will mess things up. We used to do tons of open road riding when I was young and didn't have a problem with it.
    Aug 2004
    Peoria, AZ
    625
    2strokes R different than 4's too
    I've personally "seized" up 2 84 250Rs going flat out as fast & far as possible. I had always wonderd the same thing your asking & I FOUND OUT. Got about 6 miles the 2nd time if ya really wanna know, & when it locks up hold on for a wild deceleration ride! Now those R tha supposed "air-fooler" engines, guess I didn't get them to fool anything huh!?!? I won't try that with my 85 R though, even being watter cooled which I can definately tell helps out. Now I do tha cooling trick of running flat out for 10 seconds or so then with the gas floored, turn off the engine and turn it back on. Heard that floods the head with cool gas keeping it cooler, and that has worked for me so far...
    Mar 2003
    West Monroe, LA
    847
    The farthest I have run my 86 R non stop WOT was for 5 miles down in south LA. I had no problem what so ever. I did it there and back so 10 miles all together. I do have a dial a jet installed so maybe that helped.
    86Honda250R
    85Honda250R Sold
    82Honda250R
    Tiger 200 198? Sold
    Tiger 250 198?
    Tiger 80 (need engine) Sold
    85 Tri-Z
    86 Tecate
    Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
    May 2002
    3,658
    Jetting has a lot to do with it. If you on the lean side so you have the most power you can you'll most likely be frying something. That's how my 200x project started.
