I am rebuilding carb on 1980 ATC 110.
Carb does not seem to dirty. Soaking carb in mineral spirits.
The main jet is ok. (where slide needle seats)
My question is, there is another jet in front of that that is smaller.
I removed the jet. It is just a press fit and not screwed in body of carb.
I tried running a wire through hole on bottom and goes in a 32nd and seems blocked. I ran it through the top and goes down past the 8 holes drilled in the side of it and wire stops. I tried running my welding tip cleaner through it (which the hole is .35 in size and cannot run through. Seems i looked in it and seems it is supposed to be blocked off because i can see shiny brass down hole.
Is this supposed to be blocked?
any help would be appreciated!
