Results 1 to 2 of 2
Thread: 1978 atc90 no spark
    cambridge mn
    4
    1978 atc90 no spark
    Can any one help me with my no spark problem? I would like to know what the reading on a volt ohm meter should be from the stator. I would also like to find out the switch readings, on off to ground? I have played with this thing for weeks(new plug, new coil, new points, tried unhooking on off switch). Is there a place to read a manual online?
    Any help would be great!
    Thanks
    Buddy
    Aug 2004
    Ab Canada
    4,368
    i had a similer problem...its most likely the coil..i donr have the reading off hand...but from what you describe it sounds toast...was it running befor 2?? also..try takeing some wd-40 to all the wireing connections it will reconect anythin that might be loose and what not..also the wirein is pretty simple all colour coded :s but stators are pretty cheap for em i got my for 85$ CND used
    1985 Tri-Z-
