Results 1 to 10 of 10
Thread: 85 250R FMF Fatty exhuast system
    Mar 2004
    Orange, CA
    34
    I was wondering if any fellow trikers out there have this set up? if so what jet changes were made, needle clip position and air screw setting, to make this pipe work to its fullest potential. anyone, anyone? This may be a true diehard triker question, so only reply if you know for sure.
    previous rides: 87 KX250, 86 KTM500, 84 XR500, 97 XR400, 96 RM250,96KX250,
    97CR250, 98YZ400F, 2000YZ426F, 2003YZ450F Secondary: 02 TTR125, 03 Blaster, 02 XR50 Watercraft:SeaDoo XP787 Snowmobiles:87 indy Trail, (2) 88' indy 400s, (2) 89' indy 500s, (1) indy 500 EFI. (1) 93' 650 RXL, 02' RMK 800 and a 85' 250R
    clong's Avatar
    clong is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2004
    386
    Main jet 145
    Pilot Jet 42
    Needle @ stock
    Air screw 1.5 out
    1986 Honda 350X - stock w/ supertrapp, K&N, DG wheels
    1985 Honda 250R - OEM fresh trailer queen, but I'll ride it
    1985 Honda 250R - "rider" but still pretty original
    2005 Yamaha YZ250 - stock
    2007 PW50 - stock
    2005 Chevy Silverado crew cab - red, 5.3L
    May 2002
    Southeastern Wisconsin
    3,658
    Hey chris, I answered this for you 3 hours ago.
    Phoenix, AZ.
    6,719
    Quote Originally Posted by clong
    Main jet 145
    Pilot Jet 42
    Needle @ stock
    Air screw 1.5 out
    Aren't those all stock?
    May 2002
    3,658
    That's what FMF recomends for that pipe setup.
    Las Vegas, NV.
    2,538
    The correct answer would have entailed asking you a few questions, such as:
    1. At what elevation do you frequently ride?
    2. What's the temperature where you ride?
    Any significant change in the temperature or altitude will necessitate a change in the main jet, needle position, and/or airscrew settings.
    May 2002
    3,658
    If you ask me we need to make a sticky thread about jetting. Your kinda right Red Rider but I get tired of going through the hole routine all the time. Honestly everyone that does mods needs to learn how to do jetting. Even if you knew your elevation and temp, you'd still have to know the basics to make sure everything is right. Those type of questions will just give you a base line to work with just the same as the specs already given from FMF.
    Bartlett TN
    3,083
    You are correct in saying the temp and elevation plays a key role. You also have to take under consideration that no one trike is the same off the show room. There are some that come out with more Hp than others so sometimes the "stock" numbers dont work for some. I am running a Paul Turner head pipe with an LRD silencer and still running stock jets. Now that its starting to cool off it seems to be running much better with stock carb settings. I am going to play with it to see if I can tweek it more but its all about location and your trike. Just buy a few jets from honda(3$ each) and see what best works for you............peace
    86-87 Tecate ROCK!
    Las Vegas, NV.
    2,538
    Oldschoolin & Scott, I totally agree with both of you. The unknowing person asks a simple question, which in this case does not have a simple answer, and someone gives them a cut & dried answer. I only wish, jetting a bike properly, was as simple as some people on this forum make it seem.
    Phoenix, AZ.
    6,719
    So is there a problem with making a sticky? I'm sure some simple and concise guidelines would be helpful to a lot of people.
    I've been fortunate in that I've never had to do it in more than twenty years of riding. I've always had a nice, tan colored plug by only adjusting the mix screw. That's about to change though. My R is most definitely running too rich out here.
