i have a 225 dr and i am tired of charging the battery every couple of weeks. i know that the charging system is not working. does anyone know how it works, or where i should look for problems? thanks, plk
is this forum not working?
its working, does any1 have a wiring diagram?Originally Posted by plk
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
i have a wiring harness without the coil, rectifier, and handlebar switch for an 84 225DX, if you just wanted to replace the whole thing
yep,,, it's working plk. (your posting)
i don't have any real good input on that trike (no manual) so can't comment.
i am sure you have all the basics covered, battery up to snuff, terminals good shape, battery to frame ground intact.
maybe if you have multi-meter, get it running and pull off the positive lead and see what the alternater output back to the battery is in volts. i would think it should be over 12 volts at a little higher then a idle.
you can do alot with a multi-meter and they are cheap as far as what you can find out with one (10 - 14 dollars )
guesse i had a little more to say then i thought,,, good luck.
john
i have a drso i would need to put the reverse wire on the side btw, how much anyways?
My Rides
Yamaha 200E
$30 shipped sound good?
how far do the wiresgo up to the front of the trike? just the connectors, or all the way up to the switches and stuff?
My Rides
Yamaha 200E
there is no headlight/kill switch, or coil, or rectifier, but everything else is there, (cdi, wires, connecters and everything), the ends are uncut and its in good shape
includes cdi??? so just plug it in and go? also, how hard is it to put in, have any pics?
My Rides
Yamaha 200E
yup, plug it into your engine, plug it into your coil, plug it into your handlebar switch, plug it into your rectifier, take off the rest of your wiring, and there you go, although like you said, you would have to do another wire for the reverse
have any pics?
My Rides
Yamaha 200E
here is some pics, it has all the original connectors, and has all the things EXCEPT for the handlebar switch, coil, recitifer
more pics...
and more....
