Results 1 to 12 of 12
Thread: Big motor in a Lawnmower??
    Apr 2004
    Gibbsville, Wisconsin
    60
    I was thinking of droping a V6 or V8 into a lawnmower frame. Just for giggles, would i get pulled over if i was doing under 25 with a SMV sign on the road with it?? What type of lawnmower has a strong enough frame, or a frame that I could reenforce for this.
    Nebraska
    36
    dumb, man you mean to tell me that that is the best thing you can come up with to do in your spare time?
    Oswego, IL
    1,858
    go with a deere they are the best out there!
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Mar 2003
    Barnesville,Ohio
    2,298
    a cub cadet and simplicity has a drive shaft to a transmission in front of the rear axle. they are both good tractors
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    well, it'd be ..... interesting... .. but a lamnmower frame will never hold up to the weight, for one, a riding lawnmower is only what? 3-4"x 7" (just a guess) ? , and you wanna put a v6 or v8 on it??, a 4 banger is about 10 times the size of a mower engine, and you wanna put double that?, the front end would buckle as soon as you lowered the weight of the engine on it, you would have to beef up the frame like hell., and "just for giggles" , i dont know about you, but i wouldnt wanna be driving on something where theres a v8 roaring 2 inches from my face (it will take up that much room), even if you did get the motor installed and hooked up (SOMEHOW), you wouldnt go anywhere., as soon as you put it in gear your gonna grind the tranny into a big pile of metal shavings.
    but if this is something that for some reason you really wanna do, i'd look for one of the old mowers, the older ones are alot stronger and are pure steel, the newer ones are loaded with plastic crap and whatnot (like a polaris 4x4)
    Nov 2002
    Kirkville, NY
    3,831
    A car engine would just be out of the question for reasons mentioned above. You would be much better off putting a motorcycle engine in. You can get an older rear engine mower that is chain drive for cheap then put something like a Honda cb 750 motor in it, they are a cheap inline 4 cylinder and all over the place. I was actually going to put a bike engine in a mower with one of my friends just for the challange, we bought the mower and the bike but I decided it would be more fun to put the bike on the road instead .
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jul 2004
    Alberta
    0
    Hell, I was thinking of doing that! But then I thought no, becuase even though I had an old John deer(deere?), that is pure steel I though it is just better to keep the 8hp Kohler(sp?) engine in it. I really don't have the time to do much fabricating(I have a few other projects to finish first). BTW, that old 8hp had enough brute force to pull a full sized trailer(old dodge 8' box, and it has 34" boggers) through the snow and over some think bushes, without missing a beat. For a while it was my ATV , man that thing could take me anywhere(heh, I made my own paths through and over the bushes). As they allways say "nothing runs like a deere", its true because mine is still running :P
    But if you really want to put a V8 into a lwan tractor, I would recomend an old Deere. They are made out of 1/4 to 3/8" steel compared to 1/16" or less, on many new tractors. You would also have to probably cut off the front end, so to get the engine and tranny lined up with the rear end(get yourself a diff/axle similar to the ones used on funnycars because they are shorter). I just think it is too much work, and would be prone to failure.
    Just my 2¢
    Jul 2004
    north carolina
    101
    i agree with the fox if you must use a motorcycle engine you dont have room for a motor and transmission you would have to do some kind of direct drive crap then you wouldnt be giggling you would be on the ground gurgling. i believe something like an xr 80 motor would do great or better yet find a motor with an automatic transmission and for the frame an old john deere or cub cadet would do
    later and goodluck rman
    Apr 2003
    Spanaway, WA
    1,245
    ive seen Ford 4 cylenders out of pintos and couriers in mowers used for tractor pulling.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Apr 2004
    60
    For one I just need the frame and sheet metal to make it look like a lawnmower, other wise i would use the stearing system out of the car, get rid of the drive shaft, and just go transmission to rear axel, put in a firewall, put on disc brakes, keep the thing very low to the ground, no suspension, make the frame longer, put some wide, sticky rubber on the back, some skinies on the front, and a wheeie bar on the back. This would be something I would take to tractor shows just to prove it can be done.
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by sickKLT20081
    Do you relize the custom fab work involved here? You are talking some serious work and money. Even if you got a small tractor and not a lawn tractor your not making anything that will look like a lawnmower. I guess if you did you could be on that show BIG.
    Have you ever done any measurements? This is way to long for any normal lawnmower. Once again your back to a small tractor.
    Any idea what this would cost to make it work and look good? From your description it won't look like a lawnmower, it will look like an old fasioned rail with bad fenders and a lawnmower seat.
    The only thing you would prove is that when you are done with a project like this is that you will have spent an butt load of money and it can't look like a lawnmower when your done.
    Galloway N.J.
    68
    why dont you juss build a dune buggy? it would prolly be cheaper + more reliable
    1986 200x- Not running as of now
