Thread: black soot on my spark plug
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    I put a new plug in(the correct one)i drove it on and off for about 2 hours,i took it out and it had carbon or soot on it ,what causes this and can it be corrected.thanks ......svo58
    Moncton Newbrunswick,Canada
    509
    running rich
    Jul 2004
    166
    if it is running rich how do you get the carb.to burn leaner
    509
    i'm not really 100% sure you'll have to wait for someone expeienced in this department to come accross this post,i'm to the point that if i ever have anymore carb troubles the bikes goin to the shop....
    Apr 2003
    Spanaway, WA
    1,245
    it could be needing the air filter cleaned if its not real sooty. i would say go to a leaner set of jets.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Lots of vintage and not so vintage two wheeled stuff.
    could be a minor electrical problem or it is running rich...
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Murrieta
    22
    sounds like it's running rich. #1, set your mixture leaner.
    the screw that's inlade into the carb, to the left of your idle screw, lean the mixture (more air, less gas) turn to the right. i'd start with half turns and work from there.
    #2 your air filter is clogged and not getting enough air, causing your carb to run rich, clean the filter.
    hope this helps you out some.
