Thread: 82 200 honda
    Jul 2004
    minnesota
    689
    82 200 honda
    I just got an 1982 honda 200 with 25-12-9 tires on it and i was just wondering is the only things that could leak water in the engine is the exhaust and the carb,and i got some steel flexible tubing i am going to hoseclamp to the end of the muffler, and a long piece of vacume tubing and i am going to hoseclamp that to the end of the carb and put the air cleaner on the end of the tubing and i was just wondering if this will work?, so i can go threw some major deep water.
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Yeah I guess it would work if you can keep it from flipping over. Thats the hard part. Your coil might jump fire a bit.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    83200e's Avatar
    83200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Arkansas
    356
    Re route your carb vent hose up the frame under the gas tank and make sure
    the air box is sealed good , keep the engine running and you won't have any
    problems.Let us know if you go through with the snorkel idea.I'm curious how that would turn out.
    Jul 2004
    minnesota
    689
    i whent threw with the snorkel idea today i whent and put a peice of vacume hose hoseclamped to the end of the carb and i got a peice of steel flex pipe for the xhause(i still have to put that on), but i whent and tested her in a boatlanding near my house and it worked, i whent to threw water up to about the top of the fenders, but then it started floating up, it was pritty neat, i routed the hose under the back fender and it came out by the handlebars and then i just tiestrapped it to the handlebars, ill get picks with it in action when i am going threw a big swamp.
