Results 1 to 15 of 16
Thread: fly wheel puller? or "rotor puller" as the book says
    Oswego, IL
    1,858
    ok im going to split my cases on my 85 200x so i can take out the crank and get it rebuilt my question is do i need a "rotor puller"(thats what the honda manual says) to get off the big magnet? if not how can i get it off? and do i need to take it off if im going to split the cases? i need to no asap! thanks guys o and the prject is comming along great just painted the swer(first coat) so by monday-tuesday it should be rolling and by sunday it SHOULD be runnig
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    puller
    You can use a 200x front axle as a puller. I have done it and it works well.
    83 200x, 85 trx250 fourtrax, 85 klt110
    Oswego, IL
    1,858
    what exactly do i do? thread it in and then what?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    200xkwit is offline Registered User Arm chair racerAt the back of the pack
    May 2004
    Rochester NY
    355
    well
    just thread it in the middle of the flywheel until it bottoms out against the crank and pops the flywheel off
    Jun 2004
    Dallas
    39
    Quote Originally Posted by tdup
    Never knew that....good idea
    I had to go to an industrial shop and get a bolt, I forget the size but it was metric. It only cost a buck or 2.. Honda charges prob some good $$$ for their "special puler"
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    universal puller.
    Oswego, IL
    1,858
    so i just thread it in and keep threading it in and it will push it off? and then how do i get it back on?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Apr 2002
    s.w. michigan
    6,498
    flywheel
    the bolt you remove with the washer on it will press it back into place.
    john
    Oswego, IL
    1,858
    so i just keep threading it in and it will push it off?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Apr 2002
    s.w. michigan
    6,498
    info
    you will do that with a bolt the size of your front axle ( or go buy that size from the hardware )
    the bolt you remove to start with ,,, threads into the end of the crank.
    that's the one that holds the rotor in place and also will push it back into place when you are ready.
    the bigger bolt we are talking about threads into the rotor itself and pushs against the crank to force it off.
    in other post about this howdy made a excellent point. it's best to use the correct bolt for this cuz if you use something to thread into the rotor that ain't quite right ,,, you very well might screw up the end of the crank.
    you will be needing a few other special tools for the oil rotor nut + clutch.
    john
    Oswego, IL
    1,858
    ya i got that tool made up already. so you woulndt suggest using the front axle to get it off?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Apr 2002
    s.w. michigan
    6,498
    tools
    i never have used the front axle for that myself but others on the board said they have ,,, don't recall anybody saying they screwed up the crank.
    john
    Aug 2004
    Davie
    117
    Quote Originally Posted by broook
    universal puller.
    Where do you get this puller?
    broook's Avatar
    Mar 2003
    Newfoundland
    207
    Quote Originally Posted by kryppy
    Got that from my Honda dealer but I don`t think it is a Honda make.
    When I went in to buy one he just reached under the counter and pulled it out like somebody had ordered it and never returned to pick it up.
    It is realy handy for me as I do work on trikes and m/cycles for a hobby.
    I put the duct tape on to protect the threads and useing a piece of wood on it , hit it with the and it pops right off.
    Jun 2004
    geraldton, west australia
    1,068
    try ebay for a puller.
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
