Thread: choke or throttle cable problem? or what?
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    Ok if you've been paying attention to some of my posting or post whoreing I have been having carb problems on my 86- 250 big red.
    Anyway previously my big red ran strong when on the gas but refused to idle when it warmed up, but it ran nice and strong, and would always kick over first kick after it stalled out. (it put out alot of black smoke and fouled some plugs though with black carbon.
    I moved the carb needle clip to one stage leaner and walla I have idle. but like this when ever I would go to gun it it would just sort of sputter until I let off the gas. If I rolled into the gas it wasn;t such a problem. It did this when ever I would try to gun it( like when poping a wheelie). I did notice that I had an extra high flow jet from the ones I replaced installed in the low flow position. (I don't know how I messed this up)
    So I moved the clip back to the previous rich position and magically all of a sudden the trike would idle. this is exactly as it was previously. Now the trike would run strong sometimes and other times do the sputter thing, regardless of up hill or down hill or whatever.
    another problem that developed after the last listed adjustment was the trike would rev itself up. However the throttle would be all the way back and I checked the spring on the carb and its not sticking any. (the throttle would be in the idle position) reving the gas didn;t effect it, it would still want to rev up. You can cut the engine off and re kick it and it would start up and idle fine and then do the rev up thing again after 5-10-15-20 minutes.( it did the rev up thing once or twice before but maybe once a week) the whole time doing this sometimes runnning good thing sometimes running bad.
    I still have black smoke coming out of my exhaust.
    I think maybe the choke is sticking or the throttle cable is, anyone have an idea which would be the culprit? or any other ideas as to what is going on. could it be the petcock? this was giving me some issues before, tricke would run in res but not in the on postion, now it runs in either.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    It sounds like you have rust in your gas tank. It plugs up your fuel filter,gas line, main jet and by this point,the whole carb.Try removing the gas line from the carb. and get a fuel sample in a clear glass bottle and check it for rust and water.
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    Aug 2004
    tallahassee FL
    392
    your most likely spot on. I think thats what was clogging the jets before.
    If I see rust particles in the fuel what do I do to fix it? is there a way to clean the tank or do I have to get a new gas tank ?
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    i was having the same high reving problem, my 200s would idle when it was cold but not so good after it warmed up. i made a mixture adjustment, and that fixed it.
    after riding for a bit, mine would start racing really fast, turns out my fuel cap vent was plugged up, soaked it in brake cleaner compressed the spring in the cap and blew it out, hasent done it since.
    took me awhile to realize it, but while it was racing really high, i took the gas cap off for some reason, then it slowly went to a nice idle.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
