Results 1 to 14 of 14
Thread: carb removal !@#$%
    Jul 2004
    Mud hill. close to water !
    3,658
    carb removal !@#$%
    HEEEELLLLPPPP...
    ok.. here we go again. 84 Big Red 200 ES.
    I want to remove the carb to clean it out and i can't get it out.
    I posted a while back and was told i should remove the air box and take the carb out thru that opening.
    My problem: the carb is held to the airbox with a phillips screw on a collar, there is a hole on the top part of the frame to insert a screw driver and loosen the screw, however it's not lined up and i'm afraid to force it and break the rubber boot.
    the choke cable is routed to the handle bars and is attached to the carb and i can't seem to get the cable loose either.
    The only bolts i can find to remove the air box are 2 10-12 mil bolts right next to the battery but i can't imagine this being the only thing holding the airbox on ???
    anyone by any chance willing to scan me a few pages on removin the carb from this puppy ?
    and any tips on loosening the screw that holds the carb to the airbox? without causing damage?
    i'm desperate here guys..
    83200e's Avatar
    83200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Arkansas
    356
    If the clamp isn't lined up with the hole,spray the entire thing with penetrating oil and slide the clamp with a prybar or screwdriver.Hopefully it'll slide enough to remove it.
    Jul 2004
    3,658
    Cool.. seems logical.
    i was hesitant about spraying wd-40 on the exterior of the carb like that, but since i'm cleaning it out anyways it should be fine right?
    Mar 2004
    Eastvale, CA
    630
    Tip #1 - Buy a repair manual, (Clymer manuals are a good start) you would've been done by now if you had one.
    Jul 2004
    3,658
    I bid on a few so far on e-bay but some idiot either keeps retracting their item or outbiding me at the last 0.5 second.
    I will get one as soon as possible, but i want to fix my trike NOW.
    Aug 2004
    Ab Canada
    4,368
    to get the throttel cabel out you have to unscrew the plunger on the top of the carb where the cabel go's in it unscrews like a bottel of pop :P and the rubber boot..there is normally2-4 bolts holdin the air box on..under the seat..pretty easiy to find..if you look. take the 2 nuts off the the carb holding it to the intake boot..then you should beable to move the carb+air box as one piece back and forth enough to get at the screw on the rubber boot..if not use wd-40 and pry it off...then pull it out though the air box hole or to the right or left of the carb...hopes this helps
    1985 Tri-Z-
    Jul 2004
    3,658
    Thank you !!!
    i knew how to remove the throttle cable from the carb.. but it's the choke cable that's being a trailprotrailprotrailprotrailprotrailpro.. ( i'll get that one tho.. not a huge deal )
    the carb to the airbox is the part that *****. ( will try the wd-40 and ^^^ )
    i see 2 bolts right next to the battery, i can remove those easily enough, hopefully it comes out this easily...
    THANKS AGAIN EVEYONE !!!! YOU GUYS ROCK !
    Moncton Newbrunswick,Canada
    509
    i'm off work today and home doing nothin do you want help???
    Jul 2004
    3,658
    sure..
    but maybe give me a call first to make sure i'm there.. i got a few things on the go but i really want to get to this as soon as possible !
    i'll be home by 6:30 pm.
    509
    ok ,i still got your # saved in my pm's also any certain tools we might need that i might have kickin around here?
    Jul 2004
    3,658
    don't think so.
    well.. maybe. you got compressed air ? ( either in cans or anyother means? ) or carb cleaner ? Even a spare plug would be a good thing !
    i'm going to check our Radio Shack after work and try and grab a can.
    509
    no i haven't got any compressed air(i wish i had a compressor)i had a can of air but i used it on the carb of the 110atc i had before and my cd player,,i've got a spare plug i'll bring that ....also if radio shack doesn't have air and your handy to staples they carry it..
    Jul 2004
    3,658
    Cool..
    i'm off work now , heading to radio crack, and will be home in a little over 30 minutes ( my ride is done at 6 ! and i'm a 5 minute ride ! )
    509
    sounds good,i'll give ya a ring in a bit..
