Results 1 to 3 of 3
Thread: gas leaks out of the hole on the bottom of carb.
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    it runs fine,starts rite up,but when you shut it off it starts to leak out the bottom of carb.I had another carb. i change the float (i had this carb. in and it did not leak) so i put that float in,and it does the samething but not as bad,is it the float or what.thanks ............svo58
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    You don`t say what type of carb it is but I suggest you change the float needle, or at least clean the tip and the inlet to the carb. Probibly a small piece of dirt stopping it from sealing. Sounds like it is passing and the gas is running out the overflow.
    Watertown, New York 13601
    3,382
    Quote Originally Posted by broook
    I was thinking that too.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
