Results 1 to 15 of 21
Thread: Does a DG pipe "eat" your rings ??
    May 2003
    Shediac, New Brunswick
    1,126
    Ok I bought my 200x in july I think. and well its burning oil pretty good.. The guy that had it last always changed the rings like every 6 months ?? .. When I bought it he said there was only about 2 or 3 tanks on those set of rings. Well I have about 10 more into it, and umm its burning oil.. He told me because of the lack of back pressure that the rings go fast. Is this right or ?? something else wrong?
    '84 Honda 200x
    slow restro
    Aug 2004
    Ab Canada
    4,368
    i dont belive a lack of back pressurte would make the rings go bad..it would fry the valves...as for new rings..if he did it every six months..if he honed it every time it could have caused the cylender to just ware too much and if you change them again i would suggest a bore and new piston...check the valves too
    1985 Tri-Z-
    Anaheim
    1,270
    Iam going to say valves
    cause rings dont eat up over lack of back pressure never heard that one before. make sure its not trailprotrailpro valves if it smokes when your applying throttle its the valves if it smokes when u let off the throttle its rings.
    hope yah find out trailprotrailpro problem
    adam
    Rittman, Ohio
    6,276
    Rings wear because of friction, heat, and hours of use. The pipe has nothing to do with it, unless it has been improperly carbureted as a result of the pipe. Maintenance intervals should be based on hours of use, and not on time elapsed. That he did it every six months, with knowing how much he rode it is pretty useless information. Also rings are not the only factor in looking at premature loss of compression. As was mentioned, it may need a bore job, and valve maintenace may have been ignored.
    Moncton Newbrunswick,Canada
    509
    hey chris i think he lied to you when he said the rings were changed every six months,that be just plain stupid to waste money like that,i think the ringd are pretty worn,have you had the topend opened up yet?I 'd just buy new rings hone the cylinder and see if you can get away with that..
    Apr 2007
    shickshinny
    5
    id say valve guides
    sounds like the valve guides are shated up. My xr did the same thing i changed the guides and all the seals, and it fixed the problem so check them out two ,That might be the majority of your problem
    Jul 2006
    hey um....handaxr80 you just responded to a almost 3 year old stagnant post, lol
    Apr 2003
    HARTFORD CT, USA
    478
    hahahahahahahha
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Aug 2005
    michigan
    125
    lol thats funny
    83 atc 200
    86 lt250r quadracer
    Greiver430x's Avatar
    Greiver430x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Swiftwater, Pennsylvania, United States
    444
    LMAO
    2 1978 Yamaha xs750 specials
    2008 Kawasaki KFX450R
    Powermadd handgaurds, K&N, UM Full skidplate,Dg nerfbars with heelguard and pegs.Maxxi RAZR's all around MORE TO COME.
    1987 Suzuki 230 Quadsport, all stock and one mosquito fighting machine
    Black Booger Crew member
    Ontario, Canada
    457
    lol
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Jul 2006
    western ny
    3,366
    lol omg thats funny. i wonder if he got it fixed lol
    GIT IT RAAAGGGGG !!!!
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    Quote Originally Posted by RideRed250R View Post
    cause rings dont eat up over lack of back pressure never heard that one before. make sure its not *Edited**Edited* valves if it smokes when your applying throttle its the valves if it smokes when u let off the throttle its rings.
    hope yah find out *Edited**Edited* problem
    adam
    you have this exactly backwars on how to tell what is causing the smoke. a leaking valve seal will smoke when you let off the gas.
    florida
    2,328
    a Z is a 2 stroke lol..totally difrent
    Mar 2007
    Texas
    5,045
    doh!!!!!!!!!!!!!!!!!!
    ________________
    https://www.mikesatvfix.com
