Thread: piston rings
    Mar 2004
    Fond du lac,WI
    658
    piston rings
    on my tri-moto 200 the piston rings r worn do i have to bore out the cylinder or r there just stock piston rings that fit all tri-moto 200 pistons. its a 1983 please help i wanna ride lol
    have you tryed www.wiseco.com??
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Rittman, Ohio
    6,276
    You cant use Wiseco rings on an OEM piston.
    Take your cylinder and piston to the dealer. Have them measure it to see if it needs bored. If it does not need bored, have them hone it, and order new rings for the piston you have.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    usually when you hone a cylinder your end gap on the rings gets real close to outer limits, so i usually get the next size over rings and gap the rings to the smaller end of the specs to be fresh again,,,, every little bit helps,,,
