Results 1 to 15 of 24
Thread: 440 fan
    Jul 2004
    Minniesota
    115
    440 fan
    i have a 1992 Arctic Cat Jag it has a 440 fan in it anyone have any ideas how i can get more power from it and top end
    Dec 2002
    salem, nh
    1,339
    wrong forum pal.
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    potsdam NY (upstate)
    1,437
    boysen power reeds..... also pipe it if they sell prformance pipes for it... air box vents for more air into the engine...... plain the heads for higher compression.....a good tune up..... there are some good ideas for you man...
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    i had a old cat with the same motor, what really opened it up was a good port job and wiseco pistons (fresh bore), from that point,, you can do whatever you can afford, carbs, pipes, filter, plain, lighten, etc. etc ....
    Jul 2004
    minnesota
    689
    well hondawilly i say just do what i did to my 440 arctic cat put a peice of flex pipe on the header and clamp it on it gave my 440 a hell of a lot more spped and more torque and sounded awesome and pissed alot of people off i loved that old beast
    Jul 2004
    Minniesota
    115
    i heard that can cause engine damage BS???? but my dad wouldnt like that. he got mad when i took the exaust off my threewheeler
    Jul 2004
    Minniesota
    115
    were are the reeds i am not familar with them. they dont have them in denis kirk ,only for liquid cooled sled
    1,437
    dont do that to the exaust.... on a 2 stroke messing with the exaust like that will prolly make you looz power not gain any at all..... remember a 2 stroke is tuned by the pipe on it... thats why you can change the power curv by switching pipes..... doing something like a piece of flex pipe would almost def make you looz power...... 2 strokes are alot different then 4 strokes
    also some of the older sleds didnt use reeds.... but im not sure about yours....yours being a 92 i would think would have reeds because i used to have an 85 yamaha 440 SS (super sport) and it had reeds (lol that was a pretty fast sled for its time) any way there should be an aftermarket set of reeds that you can buy for that sled.... weather your seld has 2 carbs or one there will be a "reed cage" between the carb and the cylinders of your engine ware the intake ataches to that has the reeds in it....being your sled is a twin you will have two reed cages and two sets of reeds to replace with an aftermarket set like boysen power reeds....
    if i were you if you are really seriuos about this id,
    pipe it
    aftermarket reeds
    clutch it (higher stall clutch)
    plain the heads (higher compression)
    dual carb intake (replace the "Y" intake for one that will let you use two carbs)
    also like said before you should maybe rebuild it and you soemthing like wiseco pistons in it....being the engine is 12 almost 13 years old if it hasnt been rebuilt yet it is def time for it to be then... just rebuilding it if it hasnt been should wake it up alot.
    Jul 2004
    Minniesota
    115
    thats kind of what i thought
    Newfoundland
    5,280
    Umm its a 440 fan, not sure bout urs but my cousins 380mxz is hard to find aftermarket parts for. There isnt even a pipe or silencer made for it since its a 380 fan cooled machine.
    Try some new Boyesen power reeds as urs may be old and worn out, porting was something i recommended for my cousin, gut your airbox and find some larger jets to match, take apart your silencer, you may try removing any baffles in the exaust can to improve airflow, (cut it straight down the middle and remove the sections that obstruct airflow and weld it back together) sure it'll be loud but if done right not that loud, wiseco pistons, clutch it for top speed performance, and then find any useless items on your sled that can be removed to shed a pound or two. Example would be clamp on filters for your carbs instead of the big airbox, just tell K&N your intake size on the carb and they will hook you up.
    Jul 2004
    Minniesota
    115
    i ride in powder so i think i will leave the air box were are the reeds and were can i get them
    Jul 2004
    Minniesota
    115
    i dont think it has reeds
    1,437
    my 85 440 ss had reeds......
    read my last post i added to it...
    Jul 2004
    Minniesota
    115
    i have two carbs cause i broke the piston rod pin that connect it to the crank that pin broke and i got a parts sled whit a motor a 1990 tho
    Newfoundland
    5,280
    You can get a clamp-on K&N with a Water resistant Outerwear to keep the filter from clogging up with snow. The reeds you should be able to buy from Boyesen.
