Results 1 to 10 of 10
Thread: 9 inch wheels and 4/156 bolt pattern
    Newfoundland
    5,280
    I'm lookin for a nice set of wheels and tires for my 85 Tecate. I was hoping for 8 inch wheels but they wont fit.
    I'm not sure but I guess 9 inch wheels wont fit the 4/156 bolt pattern right?
    Apr 2003
    Central New York
    1,862
    Rims 4 Tecate
    I got 10" ITP T9's in 4/156 for my Tecate and they look sweet. I dont think they do 9"
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    NICKG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    381
    the 9" will not fit the stock 85 hubs either. what you need is a set of 84 hubs, then you can use 8 or 9" wheels. they are always on eby and should cost less than 25 a set
    Newfoundland
    5,280
    yeah i was just making sure, didnt want to drop some cash on 84 hubs and spacers to match and then find out i could have went the 9 inch wheel route.
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    I think you can go with the 9inch wheel rought. the 4x156 bolt pattern is used by polaris and is the same as a 4/4. they make 9inch wheels for my scrambler and I beleive the new predator comes with 9 inch wheels in the back.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Dec 2002
    381
    Quote Originally Posted by conig
    ahh...you failed math didn't you. since when is 4" equal to 156mm? ok 1" is equal to 24.5 mm mutltply that by 4 and you come up with 156? wrong. the newer polaris' are different than the old ones. trust me, i know tecates. you need the 84 hubs for installing anything smaller than 10" on a 84 or 85 tecate
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    I have a Durablue wheel spacer catalog and it list all the hub sizes. Your 85 tecate has 4x156 right? According to this, these rear wheels have the same hub pattern: 87-04 Mojave/Lakota, Polaris Predator 500, and 89-90 Banshee
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Dec 2002
    381
    the durablue catalog is correct. but you still can't use a 4x156 pattern tecate hub on any wheel smaller than a 10" (it is too large on the back side to fit the smaller wheel) early banshee's have 10" rear wheels btw( stock 10"unless they have been changed to later stuff)
    Aug 2004
    tallahassee FL
    392
    well I didn;t fail math, and my stock rims are 4/156. I bolted up a set of carlisle 8x8inch trailer wheels a while back that were listed as 4x4 and they fit like a glove. so who knows. they wear off an ez go golf cart.
    May 2002
    Dublin, Georgia
    635
    4/4 or 4x4 he is refering to is the offset of the wheel. 4 inches inside/4inches outside.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
