Results 1 to 11 of 11
Thread: difference between 85 and 86 tri-z rear suspension
    potsdam NY (upstate)
    1,437
    hey guys i was wondering what exactly the difference between the 85 and 86 tri z rear suspensions are......
    also will an 85 axel carrier and axel off of an 85 tri z work on an 86 tri z ???
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    Mar 2003
    Kansas
    1,507
    No differences.. its all the same shiznit.
    1,437
    so only the front suspension is different such as the 86 got bigger diameter forks but the back didnt get any changes?
    Watertown, New York 13601
    3,382
    Quote Originally Posted by TRI-Zbrian
    That's correct.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    1,437
    thats very good to know because i have a complete 85 rear end to go ont he 86 frame now all i have to do is find some 86 forks and tripples to go on the 86 frame and a an unblown shock....
    1,437
    can some one tell me the other differences between them also other then the 6 speed bottom end vs the 5 speed in 85 and also the out side mounted over flow bottle that the 86 got and the larger diameter forks the 86 got and also the 23 inch tire the 86 got... other then that were there any other differences?
    Mar 2003
    Kansas
    1,507
    Nothing major.. You named most of it, except the rear rims are 9 inch and are reversable, smaller stock tires, a little more ground clearance, more travel,.. just real settle changes besides what you mentioned.
    1,437
    cool i will def be getting both of the frames to build up..... i am very intrested in your cylinders that you have had resleived with bigger bore sleives ..... i know a machinest that will also be doing my swingarm that could prolly make me a cylinder also
    Feb 2003
    southwestern NY
    641
    Brian,You should just buy my 86 Z.It comes with a bunch of extra 85 stuff also.Make me a reasonable offer.I'm in NY near Jamestown,and I need to sell real soon.
    Feb 2005
    Tamaqua,PA 18252
    36
    Question
    Quote Originally Posted by YTZ250#1
    Hi do you still have the 86 tri z 4 sale? if so what are you looking to get 4 it.
    3,382
    This thread is pretty old but did you PM him?
    2006 YFZ 450
