Anybody ever changed the 350X sprockets to get more speed?
Where can I get some? How much more speed is gained and can you tell a power loss?
i dont have a 350x,do you have the stock gearing on your bike?if so I would go with a 13 or 14 or even 15 on the front.I had stock gearing on my atc 200 and went up to a 12 but it still wasnt enought so i put a 13 on and it was fine.they say for every tooth you go up you gain 5 mph...www.rockymountainatv.com
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
I have many 350X's and I would say do not mess with the front sprocket. You need to keep the case saver in there, if you go to a bigger front you cant fit the case saver in there. I went to 36 tooth rears on my bikes,, and it helps top end ALOT. If you want top speed make sure you are using the stock 350X tires they balloon taller and taller the faster you go. Those 22s turn into 25s at 70mph. The rev limiter is a big hold back on these bikes. On my show girl with the modified cdi I have been clocked at 73mph. When my buddies 250R was getting a little tired I could out run him,, Then he rebuilt and ate me up.. good luck
