Results 1 to 4 of 4
Thread: big red electrical
    Grant, Mi
    big red electrical
    Hi. I have a atc200e and don't have any spark. I just bought it from my son-in-law & he had it started then it quit. Since I have had it I replaced the ignition switch & solenoid to get the electric start working. Now that works & I don't have any spark. I have power on the black wire to the ignition module but no power to the coil. any ideas? Thanks
    Jul 2004
    Mud hill. close to water !
    3,658
    The wire that goes to the plug is connected to a black unit ( coil ? ) that is mounted ot the frame on the left hand side of the bike, just under the gas tank.. held on with 2 screws.. if they are badly coroded, remove the 2 scres sand down the contacts and give it a try.
    Are you getting a weak spark or no spark at all. check with plug removed connected to wire, touch the tip of the plug to the head and crank it over.. check for ANY spark.
    Make sure you are in H or L, and not in between, i beleive there is a N safety thing in there.. does the 200 E have reverse ?
    Aug 2004
    Ab, canada
    1,222
    200E didnt have reverse, they were all chain drive, made till 83, I've got the 82 and 83, if you check the main 3ww page they have wiring diagrams for a 200e.
    Rides:
    82 atc 200e
    83 atc 200e
    76 chevy k20 custom deluxe
    01 ford f250 diesel
    1938 Nash Lafayette
    1925 Nash Ajax
    My band:
    www.myspace.com/epicosgiliath
    Jun 2004
    Brazil, Indiana
    1,389
    sounds like my problem...my 185 dont got a spark..i was thinkin it was my stator tho from the way it quit..i was goin up a hill and it felt like it was overheating (it does it alot) so i figured o well get up the hill and shut er off..well bad idea..it never started again...i had to have my friend..on a quad.. a 1004 suzuki z250 pull me all the way home (about 10 miles) can u imagine how much it ***** being pulled home by a quad! lol jk all u quad owners
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
