just like it says. i'm interested in some older style dull plastic that is used. i was wondering if i could wet sand it with all the proper steps and grits and clear coat it to make it shiny?
85 250SX New to me!!
85 ATC 70 stock ~ TRADED
85 ATC 70 with 138cc Lifan
83 110 restored ~ sold
85 110 restored ~ sold
83 200x restored ~ sold
02 400ex ~~~SOLD
K&N filter
K&N jet kit
EHS Racing lid
Removed choke 42 pilot DJ146 main
HMF full exhaust
AC skids
Holeshot XCR rears
14t front sprocket
IMS Roll front bumper
Graydon Proline nerfs
I tried clear coat and mine fllacked off easily. what are you useing?
I would assume you can paint plastic easy as long as it doesn;t flex too much.
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
The new Fusion paint from krylon is awesome for plastic.Bonds better than anything I've ever seen.I don't think it comes in a clear,but it does come in bright red,yellow and black.
I'm going to try dupont adheasion promoter. I use it to paint anything and everything. its a clear primer. and is made to get paint to adhear to plastics. I'll let you guys know what I experience. I need to clean up my scrmabler and three wheeler.
