I need to take the entire rear axle off my honda 110. I am having problems removing the nut that keeps the hubs on. Is there any trick - there is no cotter pin.
After I take off the hubs - whats the next step.
thanks
thanks
soak the nuts in penetrating oil or wd-40 for a wile then take a breaker bar or a wrench with a pipe on the end to break it off if you cant get it off by conventinal means
1985 Tri-Z-
Originally Posted by mywifeknowseverything
