Results 1 to 14 of 14
Thread: Timing
    peeweesp's Avatar
    peeweesp is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Milford PA
    325
    Timing
    Ok yesterday we put new piston rings in the 200s and now the timeing is off how do we correct it we didnt even think we moved the chain one of us was holding it the whole time
    Apr 2002
    s.w. michigan
    6,498
    timing
    are you sure you have the pulse generator in correct and not 180 degrees off ???
    john
    http://houseofmotorcycles.bikebandit...t_name=ATC200S
    Nov 2002
    Kirkville, NY
    3,831
    Check your manual.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    Check your cam mark vs your timing mark on the stator
    Anyone know of a new project machine for me around Wisconsin?
    peeweesp's Avatar
    Milford PA
    325
    dont have a manual lol
    i dont really know what you mean by that
    Apr 2002
    s.w. michigan
    6,498
    timing thing
    so did you get it yet peeweesp ?
    i just had a go around with mine on a 200es ,,, had to adujust it after replacing the oil seal in the pulse generator base.
    john
    peeweesp's Avatar
    Milford PA
    325
    no i didnt get it yet havent worked on it it gets spark and stuff it just wont start so we figure its the timing any ideas on how to fix it
    Apr 2002
    s.w. michigan
    6,498
    yep
    yeah ,,, i might be able to help.
    on that link in my above reply ,,, see the screws ( #15 ) that hold the pulse generator base in place ,,, loosen them and rotate that goldish coloured plate clock wise just a wee bit. try starting it and see if you get fire and all that ,, you might hafta keep adjusting it till you get it purring it like a kitten.
    if you don't get it ,,, p.m. me your address + i'll run a copy of my manual pertinent to timing your trike ( monday ).
    john
    peeweesp's Avatar
    Milford PA
    325
    ok thx
    ill try that
    Apr 2002
    s.w. michigan
    6,498
    manual
    this fella has a good deal on manuals ,,,, not to mention i like looking at his helpers .
    best investment you will ever make for your trike ( a good looking helper never hurts either - lol )
    john
    http://cgi.ebay.com/ebaymotors/ws/eB...931487949&rd=1
    Opelousas, Louisiana
    1,337
    try turning the rotor 180 degrees. last year i got a 110 for $50 and the only thing i had to do was turn it 180 degreess and it fired on the first pull for the first time in 2 years. about $800 later and month of hard work i had a nice trike.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Maine
    20
    timing is a bit** dont frig with it if trailprotrailpro not positive that its off
    My ride:
    82 big red atc 200e
    peeweesp's Avatar
    Milford PA
    325
    well first we will try what everyone else is saying then if that dosnt work we will try the timing we held the chain the whole time so if its off its probobly off by one or 2 teeth at the most maybe i dont really know
    Apr 2002
    s.w. michigan
    6,498
    timing
    i ain't got no mailing address yet peeweesp ,,, get it dialed in yet ???
    john
