Results 1 to 2 of 2
Thread: Oil in the stator housing
    Hattiesburg, ms
    First I would like to say this is a really cool forum, I've lurked around and found all kinds of usefull info. Thanks to all!! Long story short, I have an "84 atc200es that at first would not start ( no spark). After troubleshooting everything I found the problem when I pulled the stator coil cover and drained about a quart of milky engine oil out of the stsator housing. After cleaning and reassembling it fired right up.
    My question is this, Does the stator housing suppose to have oil in it? Thanks again!
    Aug 2004
    Ab Canada
    4,368
    no i dont belive there is supposed to be oil in there sounds like your oil seal is gone that go's between the cases look at this pice i think its # 28...
    1985 Tri-Z-
