Results 1 to 11 of 11
Thread: sealing 2 peice rims??
    jmsmilin's Avatar
    jmsmilin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    where can you get a new seal for the middle of them, or what is best to use?
    RIDES:
    Current OG rides:
    ~1993 300EX 1 owner (just sold)
    ~1993 TRX90 matches the 300
    ~1996 Z50R the FIDDY
    ~1992 YSR50 (sold)
    ~ATC 70 (w/suspension), ATC 185S (w/susp), 250SX, 350X, etc, etc, ALL SOLD!
    WTB: small machines - ATC70s w/ suspension, TRX90, z50, CRF/XR70/110, CT70, CT90, SL70 etc.
    Favorite riding spots:
    1. Twin Buttes, San Angelo TX
    2. Turkey Bay, LBL KY & Linton Beach in Bumpus Mills
    3. Sunnyside ATV, Wrens GA
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    There are two thoughts on this. Get the large o-ring from the dealer, or slap some gasket maker in there. Your choice
    Anyone know of a new project machine for me around Wisconsin?
    Howdy's Avatar
    Celina, Ohio
    10,079
    I just use a tube for the tires. It saves me a lot of work.
    Howdy
    Jul 2004
    minnesota
    689
    i just use some blue rtv goopy stuff it works excellent for me
    Aug 2004
    Ab Canada
    4,368
    dont use rtv or silicon it will just be a hassel in the end becuse it falls out or gets crused to much then your screwed..go to the hardwar/plumbing shop and get a big fat o-ring thats the best way to do it
    1985 Tri-Z-
    Apr 2002
    s.w. michigan
    6,498
    rims
    i sure hated those 2 peice rims ! i tubed all the ones i ever had to work on and what a chore ! i would stuff the tube in between the center so i didn't hafta break the beads on the tires but what a work out trying to stuff the tubes in there ,,,
    john
    Apr 2003
    132
    tubes, done deal!
    '73 ATC 70 fully restored
    '82 ATC 70 88cc kit, full suspension PK Racing frame
    '83 ATC 70 125m motor, electric start, lots o chrome,ipod system
    http://www.glamisdunes.com/invision/...p?showforum=50
    smokey's Avatar
    smokey is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    ravenwood MO
    221
    i used door and window silicone
    85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
    85 Big Red
    83 KLT200
    82 ATC200
    If it aint broke fix it anyway because it soon will be
    Rittman, Ohio
    6,276
    I use the O-ring AND coat the entire surface with RTV, and have never had a problem. I dont like tubes, but if it was rusted, that would be the best solution.
    Washingtons Crossing, Pa.
    2,977
    I second that but I usually give the mating suface a really good steel wooling or sanding (depending on the rust) before hand.
    Aug 2004
    Davie
    117
    Quote Originally Posted by Howdy
    Howdy
    Just figured that one out myself . Best way IMHO!!!
