Thread: 86 Tri-Z help
    Mar 2004
    32
    86 Tri-Z help
    Ok my 86 Z is running right now without a problem but I have a few questions. I just got the top end rebuilt with a 68.50 bore(.20), boyesen reeds, uni airfilter, DG full exhaust. Well, all of this was done at once to the Z because it was needing it since I was rebuilding the top end. Well my question is, I am running a B8ES plug and my carb is the 38W Mikuni(guessing a 38mm?). When I rejetted it, it was at 320, so I am guessing that is stock for an 86. I put in a 350 main jet and ran it without any problems but the plug is lighter than a brown paper bag and there is some oil on the first few threads of the plug. I am running 50:1 Amsoil with 91 octane. Anyone think I should jet it up a bit or do I have a different problem?
    86 Yamaha Tri-Z
    Enough mods but need more
    TRIZTUNES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2004
    PA.
    150
    86 Tri-z Help
    HEY!
    DON'T TOUCH ANYTHING IT IS RUNNING PERFECT.
    the 38w is stamped showing it for a tri-z.
    a tri-z is a 32mm stock.
    you can more the clip one groove.
    it will inrich it alittle.
    but i would not touch anything.
    that little bit of unburnt oil around the plug just shows you are not running too lean!!!!
    next time you take the head off have it shaved .10 .
    this way raise your compression big time.
    after you get it together take the plug out and kick it over you will hear the differents.
    TRIZTUNES OUT!!!!!!!
    Watertown, New York 13601
    3,382
    The stock carb size for a Z is 32mm. I don't think it is 34mm.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Mar 2004
    32
    Thanks TRIZTUNES. Do you think any bike shop that can rehone(sp?) a cylinder can do that to the head? I will try the clip to see how it goes but, I think I will stay here from how positive you sound.
    86 Yamaha Tri-Z
