i still have no spark on my 185s..i got a new coil and pulse unit and all else i can think of is the stator cdi box and wiring harness..can anybody help?
 Power User
						Roostin Away
						Power User
						Roostin Away
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
85' 350x !!! - selling
that sucks man..
Got a voltmeter ? or multimeter?
didnt you take the top end of this bike off..i thought i red in apost by you a wile back about that or somethingf....check see if your timein is set right
1985 Tri-Z-
Originally Posted by mywifeknowseverything
 Power User
						Roostin Away
						Power User
						Roostin Away
						i have the same problem, read my post about the stator. stator is most common problem on 185/200s. someone posted a link for a new one for $11, cant beat that!
85 250SX New to me!!
85 ATC 70 stock ~ TRADED
85 ATC 70 with 138cc Lifan
83 110 restored ~ sold
85 110 restored ~ sold
83 200x restored ~ sold
02 400ex ~~~SOLD
K&N filter
K&N jet kit
EHS Racing lid
Removed choke 42 pilot DJ146 main
HMF full exhaust
AC skids
Holeshot XCR rears
14t front sprocket
IMS Roll front bumper
Graydon Proline nerfs
 At The Back Of The Pack
						Arm chair racerAt the back of the pack
						just a suggestion,
when i put together my 185s basket case, I couldnt get any spark....my brother in law started looking around and found that the coil wire wasnt in the coil completely..after cranking for what seemed to be hours, it was fixed in minutes...just a thought other than that, try all the simple things first..plug ins tight? try a diff plug, one that you know works? is the coil grounded on the frame? (not sure if it needs to be but I make sure) timing is correct? cdi is set to the correct gap? and the best one of all, is the kill switch on run? (been there , done that one too)
Dave
 First Time Rider
						Arm chair racerNew to the board
						First Time Rider
						Originally Posted by 83185s
Check the stator with a VOM, 100 - 300 ohms is good, anything else replace it.
 First Time Rider
						First Time Rider
						Don't forget one of these!!!
The correct exciter coil ( part of the stator ) ohm reading for a 185s is 215 - 240 ohms.Originally Posted by kryppy
How to check it:
Set the ohm meter to 1000 or 2000 ( different ohm meter have different settings ). Then unplug the black with red stiped wire going to the stator. Take the 2 leads from the ohm meter put one on the metal in the conector of the wire going to the stator ( black w/red stripe ). Take the other lead and touch the bare metal on the motor. Read the ohm meter to see what the reading is. The lower the number the weaker the spark. If it is a lot higher than the spex it could damage the CDI box or other components.
I hope this helps.
Howdy
 Power User
						Roostin Away
						Power User
						Roostin Away
						yea it was the stator sry i havnt replied sooner ive been busy lately...yea i took the head apart and cleaned everything to shiny! but it runs now..it was the stator so i bought i pulse unit and coil for nothin but thats ok cause it runs better now..ive tried those champion powersport plugs..not bad at all..they give plenty of spark for mine it ran like a top...now its got a autolight..i had low funds..real low...lol..anyway thanks for the help guys it was the stator..somethin i could have fixed in less than a day but didnt reallize it was that..it looked fine but it wasnt..and no dave the coil could jsut be dangling by the wires and still run..cough cough..lol but i fixed that problem to
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
						Arm chair racerFirst time rider
						Powersports they available at any major store?
Rides
200es Big Red "Ol Bessy"- Hondaline front rack
2005 Honda 650 Rincon 27 inch ITP Muds with 14 inch C Series Wheel, one inch Bigfoot lift kit, 2500 Warn Winch, 60 Inch Moose Plow, Hondaline Front and Rear Camo Utility Bags, K and N Filter
1999 Chevy silverado V8, K and N, fiberglass bed cap, mossy oak accents, hypertech computer tuner.
 First Time Rider
						First Time Rider
						Just curious, If I wind one with 600 ohms will it explode my CDI box?Originally Posted by Howdy
....or will it melt the tip off my cheap Champion plugs.....
Another Question, do all the different ATC's take different stators? I have seen some that look different, but look like they will fit in the correct place....are they all the same OHM value 215- 240?
