Thread: tecate question.
    freeport, IL
    130
    tecate question.
    did tecate 4's or 3's have alluminum frames? did either of them?
    In Loving Memory of Jeff R. Beam
    In Memory I ride of you.
    "BEAM LIVES"
    1968-2004
    Us
    727
    T3's didn't, and i'd bet my bi-weekly paycheck that T4's didn't either.
    May 2002
    Texas
    2,670
    Tecate4's have a removable subframe. I can't remember if the stock sub-frame was aluminum or steel. I know there were aftermarket aluminum sub-frames. Their OEM swingarms are aluminum.
    86/87 Tecate 3-Wheelers OEM swingarms are aluminum. 84/85 Tecates OEM swingarms are steel.
    Like Cliff said, the main frames of all Tecates are all steel.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    NICKG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    381
    there was an aftermarket aluminum frame made for all tecates. the 84/85 was extremely rare it was remarkably similar to a franks or champion . the 86/87 was very rare, and was available for offsetting the things like the engine or steering heads and angles(tt and flat track) i saw one years ago. the tecate 4 was made by either roll or laegers for a very short time, again for tt and flat trackers, it basically was a 250r copy in geometry and used a lot of kx parts(i wanna say that klemm research had something to do with it)
