86 Tri-Z carb tuning w/ spark plug pic
Can someone throw some suggestions at me about tuning my carb? Mine is an 86 Z with a stock 320 main jet. I have installed full DG exhaust, uni air filter, boyesen reeds, .20 bore, and weisco pro-lite piston. Well I jetted from stock 320 all the way to 400. I got the clip all the way to the bottom of the needle but I am going to bump it back up one to the recommended setting. I run my bike for about 20 seconds and open it up in 6th gear. I take the plug out and it is just a dirty white with a light brown tint. But it isn't brown like a paper bag. I am running a B8ES plug and my engine gets hot and drinks coolant fast. Also, should I adjust the screw w/ a nut(pilot screw???) on the carb that is on the opposite side of the idle screw? I know I will have to jet higher but didn't know this high. But from 320, 350, 380, 400, it is starting to brown better. Could there be something else wrong or should I just keep messing with the jetting?
I almost forgot to say, that it does sputter when I opened it up in 5th and 6th gear like it was wanting more fuel or power. Other than that, the power is great till it is opened up 3/4 throttle and past that in 5th and 6th gear. Any help would be appreciated.
86 Yamaha Tri-Z
Enough mods but need more
