Results 1 to 12 of 12
Thread: no neutral light
    Nov 2004
    Fredericton N.B.
    6
    no neutral light
    I have a yamaha 200e 3wheeler with electric start. it won't run and my lights won't come on. the bulbs are good, before I charged the battery everything was fine then after installing the fully charged battery it won't start and none of my lights will come on, neutral,reverse, headlight etc. I have 12 volts at the switch but nothing anywhere else. any one have any ideas.?
    Bartlett TN
    3,083
    I know this sounds dumb but could happen, just check the connections on the battery and make sure you have positive on positive. Then I would trace from there following the wiring all the way up to the on/off switch. Also try starting it without the battery and see if there is any problem there.
    86-87 Tecate ROCK!
    Nov 2004
    Fredericton N.B.
    6
    checking
    thanks scottzj for your reply..Will check out your suggestions and post later.
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    If you did cross the terminals, then you probobly blew a fuse some where.
    Pull the plug from the block and ground it to the head, and pull the cord, or kick it what ever form of manual starting you have, and see if you have spark to the plug, then work your way back from there, the problem should become apparent eventually, but like i siad, it SHOULD become apparent, trouble shooting is the hardest part of repair.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Nov 2004
    Fredericton N.B.
    6
    I have power at the switch and at the plug but it still acts as if its shut down. still no lights of any kind.
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    Check to make sure that you didn't pull the plug off the neutral switch. They can also go bad, they wear down with time. The rest of the lights don't work off the battery, unless it is different than a 225 and it won't start off the electic unless the neutral indiator/switch is working properly or you ground the connector. If the plug in on the the neutral switch, pull it off, ground it and see if it comes to life.
    Anyone know of a new project machine for me around Wisconsin?
    Nov 2004
    Fredericton N.B.
    6
    Will try that next, olderfox....thanks
    Nov 2004
    Fredericton N.B.
    6
    getting close
    traced the ground back to the neutral switch and if I ground it right where the wire comes out then the light works but doesn't work without a seperate ground..so I can only assume that the switch is screwed or it is not going into neutral.
    Dec 2003
    Black Creek, WI
    299
    chances are the switch is shot, it happens. i had to replace one of mine
    Nov 2004
    Illinios
    20
    does the 200E have reverse?
    Nov 2004
    Fort Kent, Maine
    2,132
    Nope
    Quote Originally Posted by 1983yamaha225
    Nope, reverse comes on the 200es, and 250es
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Dec 2003
    Black Creek, WI
    299
    If it is a Yamaha it would be a YTM200ERN if it had reverse. There are 2 models of shaft drive 200's, one with reverse, one without
