Thread: tri-z water pump seal
    Mar 2004
    32
    I am going to be changing out the water pump seal. Before I start on the job, do I need to remove the whole side of the crank case? Or just remove the water pump housing and pull the impeller? If so, I would probably need a new gasket and where should I just purchase that gasket by itself? Thanks again.
    86 Yamaha Tri-Z
    Enough mods but need more
    Northern CA
    1,104
    Does this help???
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Mar 2004
    North Central Ohio!!
    2,712
    You have to remove the clutch cover as well as the kick-start assembly.
    I couldn't tell you where to get the gaskets. I just used high temp silicone on mine.
    P.S. there is a bolt behind the kick-start assembly to remove the clutch cover.
    Front royal, va
    2,186
    do it right and go to dealer and get the right gasket, like $10, and the water pump seal, get a 87- 05 banshee, $20 ,its the same part #
