Thread: What hubs fit an 81 250r axle
    Eastern Long Island
    1,688
    I want to know what hubs I can use to get a 4 on 110 pattern and maybe gain a little in width. I know 83-84 250r hubs work but they dont give any extra width. Will 86-87 200x hubs work?
    Lots O Trikes!!!!!
    3tigers is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    blaster hubs will work but i dont think you will gain any width from them.
    Aug 2002
    NY
    2,652
    well if blaster hubs fit then tri-z will fit. and if triz fit then warrior/banshee/raptor should too i dont think so though. i have a tri-z and i put warrior hubs on it. just get wheel spacers for the blaster maybe hmmmm
    Rittman, Ohio
    6,276
    ... and none of those will give you a 4/110 bolt pattern. You need to use 250x/300ex hubs if you want to ad a couple inches of width. You can also use 200x hubs, but they use short studs and you cant use newer OEM rims without changing the studs because they newer OEM rims are too thick. 200X hubs will not widen it.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by TimSr
    A slight correction: The 86-87 200x hubs are the same as the 250x / 300ex & 400ex. Those style will add a little to the width.
    The 83-85 200x hubs are the ones that TimSr is refering to.
    Howdy
    Northern CA
    1,104
    How's this???
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
