Thread: Reverse light stuck on a 93 300ex
    Nov 2004
    las vegas
    40
    Exclamation Reverse light stuck on a 93 300ex
    i went to start my bike and as soon as i turned the key on the reverse light was on.it was in nutural and the reverse handle was all the way down.yet the light was on. if i sit there switchin the key off and on for a wile the light will shut off and the nutural light will come on like it should.but as soon as i hit the start button the reverse light kicks back on. what would cause this? thanx
    Nov 2004
    las vegas
    40
    come on guys
    Bump! come on doesnt any one know
    Washingtons Crossing, Pa.
    2,977
    Sounds like either a short somewhere or a bad reverse/neutral sensor(s)- a bad sensor can wreak a little havoc on an electrical system. It's been a while since I wrenched on one (well a 250X actually) but I know the reverse/neutral sensor's (there are two on the same wire harness) are mounted on the right side under the motor near the oil pump. You need to do some trouble shooting - take off the switch harness and check the two wires for continuity - check the sensors for a open/closed fault. A set of new sensors will run you around $12 bucks. The change switch harness is $30.
    Mar 2003
    Barnesville,Ohio
    2,298
    you may have a short in the wire or a problem with the reverse system
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Nov 2004
    las vegas
    40
    we changed the ''box'' under the right front fender it helped for a month or too then the trouble came back so i aint sure? but thanx, ill check those relays and see how much honda wants
