Results 1 to 10 of 10
Thread: Help with leakie tire
    Exclamation Help with leakie tire
    Anyone know how to stop air from leaking around the little rubber plug on the inside of wheel-hub? What is that thing and do you replace it like a valve stem or what? Thanks Mike
    Opelousas, Louisiana
    1,337
    the o-ring in between two halves of a 2 piece rim?
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Aug 2004
    Ab Canada
    4,368
    that would be the valve stem you if the rubber is cracked/dried out you will have to take the tire apart and pull the stem out from the back side of the rim and go get a new one from an auto store or a tire shop, pop it in and your ready to go
    1985 Tri-Z-
    yep,you need a valve stem..try putting the little black plastic cover on it(if you haven't)it may stop/slow the leak down...
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Aug 2004
    Ab Canada
    4,368
    actually if you dont have the cover on its pretty easy to check the stem to see if it is leaking or if it is the core of the stem(the little metal thingy in the middle that gets pressed down just fill it up with air then dump some soapy water on it, it will bubble where there is a leak and it is the easiest way to see whewre a leak is on any tire...also if it is the valve stem that is leakin a little trick you can do to slow it down is spit on your finger then fill up the valve stem then put the valve cap on...it will last a lil longer
    1985 Tri-Z-
    No No No I've got you all confussed...this is a original balloon type tire that does not come apart as far as I know ,,,the valve stem and core is good, I repaired the core and now I find what looks like what I think a valve stem would look like if youwhere on the INSIDE of a tire looking at the botom of the valve stem. It's on the inside of the hub and lloks like a black rubber button from the outside. Sorry for the lack of info,,,now what do ya say??????
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    I think a pic would help us understand this better
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    It will be awhile I have the camera at home and I'm at work will try to do ASAP,,,,,
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    [QUOTE=wurthless]I find what looks like what I think a valve stem would look like if youwhere on the INSIDE of a tire looking at the botom of the valve stem. It's on the inside of the hub and lloks like a black rubber button from the outside. QUOTE]
    Sounds like a security plug or bolt to stop the tire from spinning around on the rim. Used to have them on our old trials and scramblers.
    So do you just pop it out and get anew one??/ thanks for your help
