350X carb on an 250SX??
The carb I asked for help identifying awhile back turns out to be an 350X carb whcih was used on an 250SX. I'm surprised none of you got that from my description. Will this thing fit my trike? Anyhow the 350X carb appears to have a nearly identical housing as the SX. The throttle valve is 4mm bigger and it has a different main and slow jet. The front slides into my boot but I haven't checked the rear to the airbox boot yet. How does someone know which jets to get so I don't flood my motor? What does a bigger throttle valve do - let in more air I assume?
