Results 1 to 3 of 3
Thread: 82 Honda Big Red 200E front tire removal
    Guest
    Pretty sure it is just rusted on but if anybody knows any trick for removing the front tire i would appriciate the information.
    Thanks
    Goulais River, Ontario, Canada
    90
    what do you mean? the axle is rusted, or you can't break the bead...
    for the axle what i first had to do was beat on the axle with a , but if u decide to do that, either use a piece of wood between the axle and , or unscrew your nut out enough so you don't mushroom the end... do it at own risk tho, i dont know if its possible to bend like that or what, but thats how i did it... and when you do get it off, make sure to grease it up real good before putting it back in....
    as for breaking the bead, myself i like to put a board on the tire and drive upontop of the board with my truck, and it breaks it usually first time, sometimes, the board has to be repositioned tho.
    Thanks alot, Billy Bob (Bob Menard)
    E-bay- bobby-menard
    e-mail - das_boobie@hotmail.com
    1982 Honda 250R - PROJECT
    2 - 1984 Honda Big Red 200es
    1984 Honda 200s
    1985 Honda Big Red 250es
    1987 GMC C-1500 - Modded (Project Weekend Truck)
    1997 Polaris Indy XLT 600
    2004 Yamaha V-Max 1200
    2005 Ford F-150 Lariat
    Eudora, KS
    15
    I had the same problem with my 83 200e, it was a tuff sucker to get off. Prop it on its side and keep spraying wd40 down in there over a couple days. Then beat it hard, but be careful with the threads.
