Results 1 to 11 of 11
Thread: octane fuel?
    200xkwit is offline Registered User Arm chair racerAt the back of the pack
    May 2004
    Rochester NY
    355
    octane fuel?
    ive been told to use a higher octane feul in my 200x becuase of the mods I have to it: wesico high compression pistion on .20 bore,uni air filter with holes in air box,cobra pipe, 105 and 38 jet size... now would I need to run higher octane fuel? well put it this way would it runner better? leaner/richer?
    Aug 2004
    Ab Canada
    4,368
    well for one, what octane fule are you running in it alredy, also have you noticed any popping noised or knocks from it ?
    1985 Tri-Z-
    Studytime is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Louisiana
    203
    Fuel can only take so much heat from compression (in you have an increased compression ratio, your compression takes place faster) without preignition. The preignition will cause your engine to literally melt if severe enough.
    Preignition if battled by "anti-knock" agents in your fuel. That's what octane is. You can run as low a grade as possible without knocking. So, if you run a "more expensive" gas does it give you more power? No. If you only require 87 octane, then 92 will do nothing for you. It is in no means a "treat" for your bike. However your bike with increased compression will more than likely require premium pump gas depending on your final dynamic compression ratio.
    Studytime
    May 2004
    Rochester NY
    355
    yea actually now that I think about it when I acccelerate and get on the throttle it makes a ticking noise. more or not when i get on the throttle hard. Im running 92 right now
    Aug 2004
    Ab Canada
    4,368
    what high compresion piston are you running...10:25:1???
    1985 Tri-Z-
    Nov 2004
    Louisiana
    203
    A "ticking noise"? Like a slightly louder than normal sewing machine?
    Studytime
    May 2004
    Rochester NY
    355
    yea 10:25:1 I dont know ive never heard a sewing machine... but I can hear it threw my helmet when im riding ( when i concintrate on the sound)
    the 10.25:1 compression piston runs fine on pump gas,I would just run supreme gas in it that would be enough....
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    May 2002
    Southeastern Wisconsin
    3,658
    At 10.25:1 you shouldn't need anymore than 90. It's possible your hearing the valves.
    Jul 2004
    Winnipeg, Manitoba
    50
    Yeah i think i can relate to that. I run 91 octane and it makes a knocking sound under hard excel or when im going throught deep mud it makes a knocking sound. Bascially when i really work the engine. IT was recently rebuilt with about 20 hours maybe on the rebuild. Also im runnign that weisco 10.5:1
    1984 Honda 200ES
    1985 Honda 200M - Port and Polish
    Weisco 10.25:1
    197? Mini Chopper w/ briggs 6hp
    1985 Chevy 3/4 350 s/b, w/ 4bbl holley
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    We can get 98 from the pump here in australia! thats all i run in my trike and car. Its more expensive but works out in the end in the car because the "mileage" is better. Regular is 91 in australia.
    This noise your talking about, does it only happen under load or when you are labouring? If so then higher octane will help the situation and/or try retarding the ignition timing a little or in other words make it spark later. Turn the CDI pickup the direction of the motor to achieve this.
