Original Piston 250R locks up, now what?
Yep, I've had it for about 6 weeks now, just got my ESR exhaust on it a few days ago and it's locked up. I was riding down the road, probably about 50mph and I heard some weird noise so I pulled the clutch and it died. I coasted to a stop and it wouldn't kick. There was also a small about of antifreeze around the head gasket.
I pulled the cylinder and both piston skirts are broken off. The crank appears to be ok but wont rotate from the piston in the lower end. I pulled the entire motor and am in the process of splitting the case.
Now for the big question. What should I do now? I have a TRX450R and I want the 250R to smoke it. I want to spend about $600 to $900 on the motor, so that doesn't cound a new carb, I may be able to stretch that a little.
The crank will be out so I don't know if I should stroke it while I'm there or what. What about a long rod and spacer plate? I also don't know if I should just get a .020 over Wiesco or just get a big bore cylinder. Or maybe look for a whole built motor on ebay.
I need some suggestions here, I'm kinda new to 250R's.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
