Results 1 to 12 of 12
Thread: Spark Plug Color Reading Chart
    Quickonstep is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Baltimore, MD
    368
    I have seen this come up a few times in the past few days and havent seen anything about it tech wise on this site, so here is a little contribution to the site. Enjoy!
    The First picture is of a normal plug, how it should look if it is jetted properly.
    The second picture is your plug if your engine is running to rich. Jet down a a little to correct.
    The third is a fouled plug. This happens becuase you have a crank case leak, blowby, dirty air filter, low compression, eccessive low rpm operation.
    The forth is of your plug if your machine is running too lean. Jet up a little to fatten up the mixure, or make sure the timing is set right.. This is also a tattletale of overheating.
    The last image is of a plug that has deposits on it.. not so much to worry about in a 4 stroke, but in a 2 stroke it happens due to bad oil, wrong mixture (premix) or dirt going past the air filter.
    Hope yall can use this.
    Brandon, Manitoba
    2,209
    wow, thats perfect, i was just gunna check my jetting, thanks!
    Nov 2004
    Baltimore, MD
    368
    maybe this should be sticky, and i cant remember where i got the pictures, someplace on the net a few years ago. Or even put on the main page.
    Jesse
    Brandon, Manitoba
    2,209
    i think they should put it on the main page. Good info.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Yes thats definetly main page worthy. I'll put that on there next update. Should help out alot of other people.
    Nov 2004
    Baltimore, MD
    368
    honda if youd like me to i can make a doc or a html with it setup nice and neat.. if youd like...
    Jesse
    Live Oak, FL
    15,069
    Its not really necessary, but if you'd like to that would be fine. Just email it to me
    Nov 2004
    Baltimore, MD
    368
    ok.. i can leave it like that.. seems pretty understandable... hope it helps a few people. i posted it because i have seen a few people posting about rejetting and what not.
    Jesse
    Nov 2004
    Eastern Iowa
    12
    Them pictures really help alot because I know a lot of people have that problem and the spark plug is a good way to check it.
    Watertown, New York 13601
    3,382
    Did this ever make it to being a sticky??
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    kando is offline At The Back Of The Pack Arm chair racerFirst time rider
    Saskatchewan
    212
    yes its in the tech section.
    1982 YT 125 Yamaha 1984 Honda 200 m
    HRC1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2004
    michigan
    151
    this may help also. http://www.strappe.com/plugs.html
