Just picked up an 85 200X for $50 last fall and just started screwing around with it. Previous owner said it started to make a noise so he shut'er down and didn't run it for couple years. I put new gas, plug, pulled and cleaned very dirty carb, and changed the oil. Starts on first or second kick with half choked carb. I can run'er for about 5 minutes thoough all the gears and then she dies suddenly. Almost like it siezes up after it gets warm enough. After thats it's very hard to kick over. Almost like something trying to stop the piston from moving. If I step on it hard enough, it seems to loosen up but it won't start no matter how many times I kick it. When it's cold, it's starts right up again and the process is repeated. Just this last time I heard a high pitched squeal for about 2 seconds before she siezed. Anybody else ever had or heard of this problem? I hope I can cure this problem without a total tear down but I think it's doubtful. Could it be cam chain/tensioner, rod or cam bearing, oilpump failure. I did look in plug hole and it looked like top of piston was a little sludgy. I also looked at both valve through top of head and pretty clean in there and seemed to operate fine when turning engine over. Again, any help would be greatly apprieciated.
