Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: 1985 350X pros and cons
    Jun 2004
    geraldton, west australia
    1,068
    hay fellas,
    i may be aquiring a 350x and was just wondering what you guys think of them, problems, good things and what they compare to.
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Aug 2004
    East Central, Missouri
    546
    Thumbs up Two thumbs up from me.....
    I love my '85 to death.
    Why?
    • EASY to work on
    • EASY to get parts for (unless you're going nuts and doing a full-restoration)
    • SUPER-reliable
    • has to be one of the most fuel-efficient trikes out there
    • Fantastic trail bike with GOBS of low end and it'll idle all day long AND when you want some top-end fun, it's there in spades.
    • Smooth ride and soft seat.
    I love my 250R to death but the 350X is a MUCH more "relaxed" trail machine.
    If the price is right and it isn't worn out, go for it.
    You won't regret it.
    BEWARE OF:
    • Listen for valvetrain/timing chain noise! If the X has a lot of it, steer clear! Or plan on $$$/time.
    • Check all bearings/bushings: swingarm can be a ROYAL pain to replace, axle carrier bearings are EASY as are front wheel (but figure that expense in).
    • Check front forks for leaks (or dry?). Mine leaked horribly. A local shop did BOTH for me for $65, complete.
    BADS?
    • Personally, I don't know of any "bads".
    • It's a VERY stable trike with a VERY controllable engine/drivetrain.
    I'd think that it would be easy to sell, if you had to, with the HUGE popularity of high-performance 4 strokes these days (TRX450R, YFZ450, Z400, etc.).
    I saw THREE 350X's at St. Joe yesterday!
    I KNOW I'm forgetting something but those are the general items.
    I hope this helps.
    Sorry so long.
    Good luck!
    Jun 2003
    South of Rochester, NY
    3,471
    Watch for cracked frames.... back around the rear where the seat/fender/tailight region and most importantly, around the frame at the rear of the motor.
    2nd generation 86 350X's had extra gussets added to help with the frames.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    clong's Avatar
    clong is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2004
    386
    Good points:
    Provides most usable power in all gears at all rpms
    Probably the most advanced 3 wheeler ever - 4 valve, auto compression release, oil cooler
    Very good looking - have to love those dual headlights
    Bad:
    Rare parts on ebay can be expensive
    Heavy to load in a truck (320lbs)
    Needs 2 quarts of oil and a oil filter to change oil
    Eat up drive train - chains and sprockets
    1986 Honda 350X - stock w/ supertrapp, K&N, DG wheels
    1985 Honda 250R - OEM fresh trailer queen, but I'll ride it
    1985 Honda 250R - "rider" but still pretty original
    2005 Yamaha YZ250 - stock
    2007 PW50 - stock
    2005 Chevy Silverado crew cab - red, 5.3L
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    My 85 frame was broke at that spot too bruce. Just above where you left anxle would be while riding. Its been fixed though. I havent had it long enough to find any pros or cons. I love it though.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Jun 2004
    Oregon
    1,784
    Actually,trying to start a 350X can be a pain for novice riders....
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    clong's Avatar
    Jan 2004
    386
    I actually think my 350X is easier to start than my 200X. My 200X has a 12:1 piston though that can make it a beyothch to start. You have to get the compression stroke at the right spot.
    2007 PW50 - stock
    Mar 2003
    Barnesville,Ohio
    2,298
    NO CONS! just pros...a 350x is the best bike ever made. but you have to tighten your hubs all the time because of the power!
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Jun 2003
    3,471
    Quote Originally Posted by ClayW
    That's how I know the Showgirl has always been loved! It's one of the first 3000 off the production line in '85, and the frame is straight, no repair welds, and no cracks! The Go-Go's a 86, and its fine where you are talking about but the seat part/sub frame is cracked all to heckola ....
    Bruce
    Aug 2002
    Creswell, OR
    889
    I had one as well no cracks, that is until my hubby got a hold of it. It is now there.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Mar 2004
    1,727
    My 350X cranks on the firts or second kick every time. Yesterday it got down to 35 and it still fired off first kick,.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Aug 2004
    546
    Couldn't have said it better myself.....
    Quote Originally Posted by clong
    Good points:
    Bad:
    That statement about Ebay is SOOOOO true.
    Amazing what people are getting for the more rare components.
    I couldn't believe how much easier my R is to load than the 350X.
    WOW! 30+ lbs. makes a HUGE difference.
    Otherwise, oil filters, sprockets and chains are readily available.
    That brings up the plastics:
    • Buy one with the best plastic you possibly can!
      Factory Honda is awesome but ungodly expensive to buy nowadays.
      Maier is available but the fit/finish just isn't Honda.
      Don't say "Oh, I'll buy some good used Honda and restore it.....".
      It's amazing what people are getting for that stuff. $$$
    You want this to be a fun experience, not a money pit.....if you can avoid it.
    Roanoke, VA
    4,038
    Good points:
    Bad:
    320lbs is light compared to the sport quads today (or utility quads ) and the oil and oil filter are what you are going to find on any ATV (except for a few that used screens). But the 350X uses the same oil filter that most Honda's use...even today. The SX uses the same filter and I think my Foreman uses the same one also. Costs $3
    Just be sure to check the mentioned frame problems and you should be set. Good luck
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    markdb420's Avatar
    markdb420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Virginia Beach, VA
    413
    I have a 85 frame that cracked right above where the right foot peg mounts, and the previous owner did a crappy welding job, it was not done properly and it caused the swingarm to be cockeyed. I got a late 86 frame and it too is cracked there, and is waiting to be welded properly.
    I echo the comments about it watching engine noise, but otherwise the 350x is the favorite one of my 3 3wheelers to ride around the house. It is reliable and decent power!
    06 Yamaha Bruin 4x4
    04 TRX Rancher 400 AT 4x4 GScape
    86 ATC 250es Big Red
    84 ATC 200s (31 yrs running strong)
    13 F150 4x4 SuperCrew 5.0
    00 Excursion V-10 lifted with 35s
    ____________________________
    Gone
    07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
    Opelousas, Louisiana
    1,337
    yeah the oil filters on it are interchangeable with a bunch of honda bikes.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
