Results 1 to 3 of 3
Thread: Stubborn 200E
    Washington State
    90
    Stubborn 200E
    Hi everyone.
    I have an 82 atc 200e. It leaks gas all over the top of the motor , from the carb. I repalced the hose, the clips, and made sure everything on the carb was tight. I turn on the fuel valve, and instant gas onto the top of the motor within seconds. Any Ideas as to what would be causing this? Thanks for all the help.
    74 K-2 ATC 90
    83 ATC 110 "Blue"
    83 ATC 185s
    84 ATC 110
    84 ATC 200x
    85 ATC 250sx "stud"
    87 BIG RED (Project)
    :QuadsOwn
    85 TRX 125
    86 TRX 125 X2
    May 2002
    Dublin, Georgia
    635
    Where is the gas coming out of the carb? If it is coming from the overflow, your float is likely not funtioning and therefore not cutting fuel flow to the bowl.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    Have you checked to make sure that your fuel switch is not leaking? If you are sure that and the hoses are fine then it has to be the carb fuel overflow. There should be a hose attached to the bottom of the carb bowl. That is the carb overflow. THe hose keeps the fuel from hitting the engine, although the carb shouldn't overflow like you say it is. Either the float is stuck, mis-adjusted, or is broken. Pop the bowl off the carb, remove the float and check it for cracks. If it looks alright and upon re-installation the carb still overflows, you will need to adjust the fuel height by bending the float tang. Instructions are in the service manual, or we can help you out with that. Send me a PM if you need more detailed instructions.
    Anyone know of a new project machine for me around Wisconsin?
