Anybody had the rear brakes stick on their 250R? I have rebuilt the caliper, it starts out OK but slowly sticks as you use them. Finally locking up the rear.
I have no experience with an 84 R but it sounds like a master cylinder problem to me. Or possibley try to loosen the rod that pushes on the master cylinder. I had a similar problem on a Mustang and I had to ajust the rod that connects the pedal to the master cylinder.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
Had a similar problem on a 200X. Make sure you have all the air out of the brake line. A small air bubble will kill you. When it heats up from use the air bubble expands causing pressure on the brakes. This may not be your problem, but it is something to check.
84 ATC200X--Wife rode it once, now I can't get it back.
84 ATC250R--Trying to find piston for 300R kit.![]()
85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
